JSmallberries
Feb 17, 2021Aspirant
192.168.1.86 refused to connect
ReadyNAS Duo Windows 10 RAIDAR 6.5 Chrome won't access admin page: 192.168.1.86 refused to connect
Feb 18, 2021Guru - Experienced User
Maybe try restarting it. To that gracefully you can hold down the power button until the LED flashes (which should take about 5 seconds).
See page 14 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
JSmallberries
Feb 18, 2021Aspirant
Good thought but no luck. Restart didn't work. I still get the same browser error.
- StephenBFeb 18, 2021Guru - Experienced User
Do you still have access with windows file explorer (or finder)?
Is ssh enabled on the NAS?
- JSmallberriesFeb 18, 2021Aspirant
Thanks Stephen. Perhaps we're getting closer. Explorer sees it and generates this
I don't know about ssh on the ReadyNAS but nothing has really changed on the laptop except I upgraded Raidar from 6.3 to 6.5
That screenshot isn't working out to well. I'm getting "an unexpected error is keeping you from copying the file...
Error 0x80004002: no such interface supported
A search for that code yielded this:
I thought it might be some new Windows 10 security thing so I tried to access the NAS from an ancient chromebook. No dice. Same refusal to connect.
