Philip_77
Jul 14, 2015Aspirant
Bittorrent Sync for ReadyNas Duo v2 available?
Its seems to me that there are only 3 apps available to my REadyNas Duo V2, Radiator 5.3.7. Can this be true?
Especially I would like to run Bittorrent Sync on it. I tried manually installing it, from teh app collection on the website, but got the error message "Bad architecture".
What am I doing wrong?
- StephenBGuru - Experienced UserThe RN100 and RN200 series are closest to what the OP has now. They are also part of the OS6 line, but are listed under "home" products. http://www.netgear.com/home/products/co ... dynas.aspx
Unfortunately the duo-v2 and the nv+-v2 had a short life, so there simply isn't much incentive for app developers. - RXLuminary
Philip_77 wrote: Not a great selection for 5.x. Can I upgrade to 6?
It is not possible to upgrade the firmware of your Duo v2 to OS6 firmware. However, if you plan to upgrade to a new hardware which is a ReadyNAS OS 6, then that would be a good choice for me.
Kindly check this link: http://www.downloads.netgear.com/files/ ... -RN700.pdf - Philip_77AspirantYes I think you are correct.
Not a great selection for 5.x. Can I upgrade to 6? - StephenBGuru - Experienced UserThere are some apps here:
http://kb.netgear.com/app/answers/detail/a_id/24586
and
https://rnxtras.com/readynas-os5-arm
No bittorrent sync though. It sounds like you tried installing an app for 4.2.x or OS6.
