stian89
Dec 07, 2010Aspirant
Can't make Automatic and Transmission work
Hi! I have Automatic v0.6.4-readynas-0.9.7 and Transmission v2.11 installed on my ReadyNAS duo. I've tried to setup Automatic to download torrents automatically, but I can't figure it out. Her...
WhoCares_
Dec 05, 2011Mentor
Nope, since Automatic only retrieves .torrent files, not the actual download. It should place the .torrent file in the folder you specify, that's correct. If it doesn't when run as a daemon but does so when run from the command line, then you have a permission issue. Make sure the "admin" user has write access to the folder where you want the .torrent files to be placed by Automatic.
-Stefan
-Stefan
