nigelivy
Sep 23, 2020Aspirant
Can't rebuild the volume on ReadyNAS NV+ v2
Hello! I'm having a problem with my ReadyNAS NV+ v2 in that I cannot restore to factory settings. I keep getting the error shown in the attached screenshot. I've tried taking all the drives out and ...
nigelivy
I should mention that I'm trying to rebuild the volume with 4 x 6tb drives.
Sandshark
Sep 23, 2020Sensei
Your NAS is 7-10 years old. It was replaced by units runing OS6 about 7 years ago. Perhaps you bought it used and don't realize that. But blaming Netgear for failure to support drives of a size that was not available when the NAS was manufactured is unreasonable. It is also a home NAS, not a business NAS, and few at that time needed huge amounts of space for home use. The max drive space in the spec is 12TB, which is based on a RAID5 of 4x4TB. There is only one 4TB drive on the compatibility list, though others certainly do work. It may be possible to push the space beyond 12TB once a valid volume is created, but I wouldn't count on it.
Yes, you probably do need a new NAS if you need that kind of storage space. If you purchased the NV+V2 new, then it has served you well and it's time to upgrade. If you purchsed t used, you have learned a valuable lesson to do your homework regarding the capabilities and history of a product before you purchase.
If a new NAS is not a possibility, see if it can create a volume on just two of the 6TB drives. If it does, try expanding that or creating a second volume (which would require you switch the unit to FlexRAID mode instead of XRAID).
