simonk1969
Apr 10, 2013Aspirant
Connect error code: -300
[2013-04-10 13:54:28] [Info] Starting backup job "GlenshielRd_NAS" [2013-04-10 13:54:28] [Info] Replicate addon version: 1.1.6 build R1 [2013-04-10 13:54:28] [Info] Locking target folder: /c/Glenshi...
de_niro
Jul 18, 2013Guide
Replicate relies on a virtual network interface of ReadyNAS Remote to transfer data,error code -300 should be network issue between 2 Replicate units,please download logs and check 'Network_setting.log' to make sure the Virtual NIC is running on both units
if Remote is functional,you will see the interface as below:
LeafNets Link encap:Ethernet HWaddr EA:61:53:E8:8E:B4
inet addr:5.180.10.* Bcast:5.255.255.255 Mask:255.0.0.0
inet6 addr: fe80::e861:53ff:fee8:8eb4/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1400 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:59 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:500
RX bytes:0 (0.0 B) TX bytes:20828 (20.3 KiB)
- Jan 17, 2016Retired_Member
