rteguy
Apr 07, 2017Aspirant
Copy Failed with Replciate - OK, what file?
[2017-04-07 11:52:14] [Info] Copy in progress [2017-04-07 12:04:13] [Error] Copy failed Total files transferred: 37 Total files size transferred: 219.54 MB Average speed: 312.23 KB/s Exit cod...
Apr 07, 2017Guru - Experienced User
Did you check the log zip file, or just look via the web ui?
You could of course look at both systems, and try to reconcile the directories. Painful, but it should get you there.
- rteguyApr 07, 2017Aspirant
I get an email, which is the same as the web ui.
Where is the log zip file?
- StephenBApr 07, 2017Guru - Experienced User
There'a a "download all logs" link on the top right of the log page in the web ui. Click on that, and after some thought the NAS will download the log zip to the PC.
- rteguyApr 10, 2017Aspirant
I downloaded the logs and went through them. No file error to speak of. There does not seem to be anything related to Replicate in the logs. That's what's throwing the error. Replciate doesn't say what the file is with the issue and there are no file errors to speak of in the logs.
Weird that Replicate doesn't say what it has an issue with.
Thanks for the attempt.
