rteguy
Apr 07, 2017Aspirant
Copy Failed with Replciate - OK, what file?
[2017-04-07 11:52:14] [Info] Copy in progress [2017-04-07 12:04:13] [Error] Copy failed Total files transferred: 37 Total files size transferred: 219.54 MB Average speed: 312.23 KB/s Exit cod...
Apr 07, 2017Guru - Experienced User
Did you check the log zip file, or just look via the web ui?
You could of course look at both systems, and try to reconcile the directories. Painful, but it should get you there.
rteguy
I get an email, which is the same as the web ui.
Where is the log zip file?
