rteguy
Apr 07, 2017Aspirant
Copy Failed with Replciate - OK, what file?
[2017-04-07 11:52:14] [Info] Copy in progress [2017-04-07 12:04:13] [Error] Copy failed Total files transferred: 37 Total files size transferred: 219.54 MB Average speed: 312.23 KB/s Exit cod...
rteguy
Apr 10, 2017Aspirant
I downloaded the logs and went through them. No file error to speak of. There does not seem to be anything related to Replicate in the logs. That's what's throwing the error. Replciate doesn't say what the file is with the issue and there are no file errors to speak of in the logs.
Weird that Replicate doesn't say what it has an issue with.
Thanks for the attempt.
rteguy
Apr 12, 2017Aspirant
I fixed it.
In Replciate, you select the folders you want to backup. There was a main folder and we were backing up 11 of 12 folders.
In a cleanup, we moved and deleted several of the 11 folders. Replicate was still looking for those folders. The copy error was not being able to find the folders. I wish it had jsut reported "Can't find the folder Surveys" or whatever.
Once I went into Replicate and fixed the folder selection, it was fine.
