eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares:
viewtopic.php?f=47&t=62337
What are your experiences on this?
Hey Netgear, I can't understand why you don't have a dyn dns client built-in in FrontView - it amazes me. Let me remind you that it's 2012.
- DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings from DynDNS etc.
DynDns - the old one, might work, never worked for me.
- etonLuminaryOk DynDNS.org seems to update correctly, though we still might need a work around for the 30 days thing.
But No-IP is much harder.
This might be useful for the 30 days limitations workaround:ddclient checks /var/cache/ddclient/ddclient.cache against the ip it get from http://checkip.dynsdns.org. If the ip address is the same, it won't update even though your http://yourhost.dyndns.org resolves to a different ip address.
http://www.dyncommunity.com/questions/9 ... pdate.html
And here is something for No-IP:
http://www.astaro.org/gateway-products/ ... s-tab.html - SandsharkSensei - Experienced UserI have confirmed that the following configuration template works (at least for the first update) with DDClient 3.8.1 x86:
EDIT: See later message, this turned out not to work fully.
Don't know how to confirm whether SSL is being used for the update.
Have also found a couple of non-fatal bugs, posted in a separate thread. - etonLuminaryThanks Sandshark!
If you like to use a secure address, why not use:https://dynupdate.no-ip.com/nic/update
Source: http://www.no-ip.com/integrate/request
Now, my DDclient settings looks like this. The DynDNS.org settings works, yes without skip=, but it's probably more correct to have skip=.
But I am not sure if I am doing this right with two services.
pid=/var/run/ddclient.pid, \
## DynDNS
protocol=dyndns2, \
use=web, web=checkip.dyndns.com, \
server=members.dyndns.org, \
login=my_nick, \
password='my_password' \
my_domain.dyndns.org
## No-IP
daemon=600, \
ssl=yes, \
use=web, \
web=http://ip1.dynupdate.no-ip.com/, \
protocol=noip, \
server=https://dynupdate.no-ip.com/nic/update, \
login='my_email', \
my_domain.no-ip.org
Note: I've seen that some of the older setups for No-IP uses protocol=dyndns2. - SandsharkSensei - Experienced User
If you like to use a secure address, why not use: https://dynupdate.no-ip.com/nic/update
Didn't think that was the way to do it since none of the example templates I found included the http:// or https:// in the server= directive. I thought the ssl=yes told it to use https instead of http. But if it seems to work for you, I'll try it. Better to have the belt and suspenders in this case.without skip=, but it's probably more correct to have skip=.
I don't have the skip= either. Haven't found any good explanation as to what it does and all seems to be working without it. But I only have one service to update, too.
I'm still waiting for the second update, as my IP address has not yet changed. I used DDclient to only update a currently unused redirect and kept the Windows No-IP DUC for the others until I see that the updates are occuring as they should as my IP address changes. - etonLuminary
Sandshark wrote: If you like to use a secure address, why not use:
You might be very right. I referred to a help page at No-IP that mostly talked about the "The HTTP Request" method. I will remove the https:// from my server settings. And for DynDNS.org http://dyn.com/support/clients/linux/ddclient/ they state that they support ssl=yes.
Actually DynDNS.org has alwasy worked for me, no matter how the settings are written. I think that DynDNS.org are more service minded and forgiving. I guess they have to be that, being so big, they just can't handle to much user support. It seems like they in the receiving end has done a lot of program adjustments to fix user made syntax faults. Like the skip= thing, they know that very many users uses their IP-check and that they from the beginning had that stupid leading text "Current IP Address: " and that many probably will not use skip. So they take care of that, almost like well made web forms that remove leading and trailing spaces etc.
But No-IP is a totally different game. It seems like the settings gotta be perfect, in order to work.
I also wait for my next IP update. Infact both my services points to the same server :) I just wanted to have redundancy. But No-IP has given me much more work than expected.
Here are most of the settings explained in a good way:
https://calomel.org/dyndns_org.html
If the mess continuous with No-IP, then I will try some other like opendns.com. - etonLuminaryWell I got a new expiration warning from No-IP. The fact that most dynamic addresses given by ISPs last longer than 30 days is a problem. This is discussed earlier in the thread. Is there some easy work around for this?
Your domain was last updated on 2012-11-12 11:52:16. Free Dynamic DNS
hosts must be updated by logging into your account on our website and clicking
update, this must be done every 30 days. If you are using the Dynamic Update
Client and your IP address has not changed within the past 30 days, you must
manually update it to prevent them from being removed from our system. - etonLuminaryNo-IP has been a mess from the start. So now I'm a happy non user.
Here is a good blog post about alternative dynamic DNS services:
http://www.turnkeylinux.org/forum/gener ... lternative
But DynDNS.org still works fine for me. If you have an old working DynDNS account, keep updating it. - etonLuminaryddclient research
# find / \( -path '/c' -o -path '/USB' \) -prune -or -iname '*ddclient*' -exec ls -ld {} \;
-rwxr-xr-x 1 root root 3696 Apr 7 2012 /etc/init.d/ddclient
-rw-r--r-- 1 admin admin 118 Apr 7 2012 /etc/frontview/apache/addons/DDCLIENT.conf
-rw-r--r-- 1 admin admin 884 Jan 22 03:37 /etc/frontview/addons/DDCLIENT.remove
drwxr-sr-x 4 admin admin 16384 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT
-rw-r--r-- 1 admin admin 0 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/language/zh-cn/DDCLIENT.str
-rw-r--r-- 1 admin admin 0 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/language/de/DDCLIENT.str
-rw-r--r-- 1 admin admin 0 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/language/fr/DDCLIENT.str
-rw-r--r-- 1 admin admin 0 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/language/ja/DDCLIENT.str
-rw-r--r-- 1 admin admin 0 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/language/ko/DDCLIENT.str
-rw-r--r-- 1 admin admin 351 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/language/en-us/DDCLIENT.str
-rw-r--r-- 1 admin admin 0 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/language/zh-tw/DDCLIENT.str
-rw-r--r-- 1 admin admin 380 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/DDCLIENT.xml
-rwxr-xr-x 1 admin admin 2702 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/DDCLIENT_HANDLER.pl
-rw-r--r-- 1 admin admin 1677 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/DDCLIENT.html
-rw-r--r-- 1 admin admin 8097 Apr 7 2012 /etc/frontview/addons/ui/DDCLIENT/DDCLIENT.js
drwxr-sr-x 2 admin admin 16384 Apr 7 2012 /etc/frontview/addons/bin/DDCLIENT
-rwxr-xr-x 1 admin admin 38 Apr 7 2012 /etc/frontview/addons/bin/DDCLIENT/DDCLIENT_service
-rwxr-xr-x 1 root root 814 Mar 28 2010 /etc/ppp/ip-up.d/ddclient
drwxr-sr-x 2 admin admin 16384 Jan 22 03:37 /etc/ddclient
-rw------- 1 admin admin 1001 Jan 25 16:59 /etc/ddclient/ddclient.conf
-rwxr-xr-x 1 root root 129651 Apr 7 2012 /usr/sbin/ddclient
drwxr-xr-x 3 root root 16384 Jan 22 03:37 /usr/share/doc/ddclient
-rwxr-xr-x 1 root root 1693 Jul 11 2011 /usr/share/doc/ddclient/examples/sample-etc_rc.d_init.d_ddclient.lsb
-rwxr-xr-x 1 root root 1850 Jul 11 2011 /usr/share/doc/ddclient/examples/sample-etc_rc.d_init.d_ddclient
-rw-r--r-- 1 root root 877 Jul 11 2011 /usr/share/doc/ddclient/examples/sample-etc_cron.d_ddclient
-rwxr-xr-x 1 root root 802 Jul 11 2011 /usr/share/doc/ddclient/examples/sample-etc_rc.d_init.d_ddclient.redhat
-rwxr-xr-x 1 root root 856 Jul 11 2011 /usr/share/doc/ddclient/examples/sample-etc_rc.d_init.d_ddclient.ubuntu
-rw-r--r-- 1 root root 2059 Jul 11 2011 /usr/share/doc/ddclient/examples/sample-etc_ddclient.conf.gz
-rw-r--r-- 1 root root 856 Apr 7 2012 /usr/share/man/man8/ddclient.8.gz
drwxr-xr-x 2 root root 16384 Jan 22 03:44 /var/cache/ddclient
-rw------- 1 root root 1347 Jan 26 08:16 /var/cache/ddclient/ddclient.cache
-rw-r--r-- 1 root root 47 Apr 7 2012 /var/lib/dpkg/info/ddclient.conffiles
-rw-r--r-- 1 root root 1088 Jan 22 03:37 /var/lib/dpkg/info/ddclient.list
-rwxr-xr-x 1 root root 228 Apr 7 2012 /var/lib/dpkg/info/ddclient.postinst
-rwxr-xr-x 1 root root 115 Apr 7 2012 /var/lib/dpkg/info/ddclient.postrm
-rw-r--r-- 1 root root 1354 Apr 7 2012 /var/lib/dpkg/info/ddclient.md5sums
-rwxr-xr-x 1 root root 186 Apr 7 2012 /var/lib/dpkg/info/ddclient.prerm
-rw-r--r-- 1 root root 6 Jan 26 01:22 /var/run/ddclient.pid
WhoCares ddclient conf file/etc/ddclient/ddclient.conf
- arnomcAspirantfor DynDNS users that kept active their account (or new members using the basic free service offered by Dlink here : https://www.dlinkddns.com/login ; which is in fact operated by DynDNS), here is a page where to you can make an automatic settings file and it's working !! (you just have to change ###password### for you real password ... simple but i made the mistake lol).
https://account.dyn.com/entrance/?return=%2Ftools%2Fclientconfig.html
EDIT : you just have to check that the 'lines' are correct in their \ (and the carriage return) ; because the automatic config file obtained can have few mistakes (that's why i didn't pay attention on changing password). Just rearrange it, it's easy. - etonLuminary
arnomc wrote: for DynDNS users that kept active their account (or new members using the basic free service offered by Dlink here : https://www.dlinkddns.com/login ; which is in fact operated by DynDNS), here is a page where to you can make an automatic settings file and it's working !! (you just have to change ###password### for you real password ... simple but i made the mistake lol).
Thanks!
But today I got this from dyn.com (former DynDNS.org):If you would like to maintain your free Dyn account, you must log into your account once a month. Note that using an update client will no longer suffice for this monthly login. You will still continue to get email alerts every 30 days if your email address is current. Failure to login once per month will result in expiration and loss of your hostname.
They are forcing their active users to become paying customers. In other words dyn.com is dying.
