  • Thanks for the link.
    What can I do with the bin file "noip_1.1.bin" ? Where to copy it ? Do I have to install anything ?
    I'm very new on it and don't know a lot about that. I don't even know how to acces linux interface.
    Could you help me ?
    Thank you.
  • I have installed noip 1.1 as a local image in the system menu.
    It appears a no-ip.log file into media witch says :
    Can't locate configuration file /usr/local/etc/no-ip2.conf. (Try -c). Ending!
    What can I do ?
  • I couldn't get the addon to work initially, but then I read the post by rmfield and copied the /etc/no-ip2.conf to a new location in /usr/local/no-ip/
    Now it seems to work fine.
    The addon still gives error messages when trying to start up from frontview, but no-ip -S gives ok and no-ip does update the IP
  • how i have to set the parameters?
    it doesn`t work this:
    -u username -p password -U 300
  • How can I access to the file
    /etc/no-ip2.conf
    if I use Windows 7 ?
    My problem is that the IP is not send anymore by the ReadyNas Duo. I don't understand why and I would like to know if it is really sent and if my router doesn't let it go out.
    How can I see if the information is sent ?
    Thanks
  • Thanks super-poussin for this!
    Dns-O-Matic has got problems with No-IP and ddclient was not easy to configure and might not even work with No-IP.
    Notes:
    I had to click save in FrontView twice to make the NOIP add-on start.
    According to media/no-ip.log
    -U = minutes
  • I have uesd no-ip ad-on for a while but it does not seem to work. After a while I get a message from NO-IP that I have not updated my address and they will remove it in 14 days. There is no problem med my connection. DNS-o-Matic forks perfectly with dyndns.org.
  • I have instal http://www.readynas.com/contributed/sup ... IP_1.1.bin
    but system can'not start the service
    I put parameters in line .
    Please describe what should I do step by step
    Best regards Tom
  • No-IP is just a mess. I don't use their services nor the client anymore.
    But for your information here is an old log file from the no-ip client. Off course it didn't work for me either.
    USAGE: no-ip [ -C [ -F][ -Y][ -U #min]
    [ -u username][ -p password][ -x progname]]
    [ -c file][ -d][ -D pid][ -i addr][ -S][ -M][ -h]
    Version Linux-2.1.9
    Options: -C create configuration data
    -F force NAT off
    -Y select all hosts/groups
    -U minutes set update interval
    -u username use supplied username
    -p password use supplied password
    -x executable use supplied executable
    -c config_file use alternate data path
    -d increase debug verbosity
    -D processID toggle debug flag for PID
    -i IPaddress use supplied address
    -I interface use supplied interface
    -S show configuration data
    -M permit multiple instances
    -K processID terminate instance PID
    -z activate shm dump code
    -h help (this text)
    Configuration file '/etc/no-ip2.conf' is in use by process 1287.
    Ending!
    One no-ip process is already active,
    and the multiple instance flag (-M) is not set.
    Auto configuration for Linux client of no-ip.com.
    Multiple network devices have been detected.
    Please select the Internet interface from this list.
    By typing the number associated with it.
    0 eth0
    1 LeafNets
    You have entered an incorrect username
    -or-
    an incorrect password for this username.
    Version Linux-2.1.9
    -F force NAT off
    -h help (this text)
    0 eth0
    1 LeafNets
    Only one host [stilarkivet.myftp.org] is registered to this account.
    It will be used.
    New configuration file '/etc/no-ip2.conf' created.
    0 eth0
    1 LeafNets
    -or-
    Version Linux-2.1.9
    -F force NAT off
    -h help (this text)
    0 eth0
    1 LeafNets
    It will be used.
    It will be used.
    Configuration file '/etc/no-ip2.conf' is in use by process 1772.
    Ending!
    Instead I would reccomend WhoCares DDclient and some other service than No-IP.
    Check out my research here: viewtopic.php?f=36&t=62612
ProSupport for Business
