Wilco87
Sep 07, 2013Aspirant
How to make database with PhpMyAdmin
Hi all there, this maybe a nOOb question but I have been trying allot and reading at google, still It aint working for me. Can someone give me a start up on making the database server ? This i...
Wilco87
Sep 20, 2013Aspirant
InTheShires wrote: I tried to find "WhoCares?" (Dev of many addons) small tutorial for getting setup properly with PHPMyAdmin, but unfortunately he's updated some of his website and the page that explains it is no longer showing.
But yes these boards are virtually dead these days. You might get "lucky" and get some folk offering help via Teamviewer but rarely do the posters post back any of the solutions they received.
Have you tried this?I got the message not allowed to login without password so i changed:
[READYNAS]:\webroot\phpadm\libraries\config.default.php
In the [config.default.php] file line 363:
$cfg['Servers'][$i]['AllowNoPassword'] = false;
to :
$cfg['Servers'][$i]['AllowNoPassword'] = true;
You are on a Duo v1 yes, the older SPARC model?
Hi,,
Thanks for your replay, yes I am on the V1 sparc model.
The folder you refer to doesnt exist, when I browse the server the normal way ( windows explorer ) but also not when i try to cd/foldername/ it in putty. The AllowNoPassword is at the True option, thats what i got so far in the PHPmyAdmin config module.
I made a server in that config area, I can change some settings, I can download the config.php file. But if I have that file, I cannot place it back because I have no folder to put it to. Still next to that its strange that if the no password is set to true, it stil doesnt login the server where I can setup databases and that kinda stuff.
