Wilco87
Sep 07, 2013Aspirant
How to make database with PhpMyAdmin
Hi all there, this maybe a nOOb question but I have been trying allot and reading at google, still It aint working for me. Can someone give me a start up on making the database server ? This i...
Wilco87
Sep 24, 2013Aspirant
InTheShires wrote:
Wilco87 wrote:
The folder you refer to doesnt exist, when I browse the server the normal way ( windows explorer ) but also not when i try to cd/foldername/ it in putty. The AllowNoPassword is at the True option, thats what i got so far in the PHPmyAdmin config module.
I made a server in that config area, I can change some settings, I can download the config.php file. But if I have that file, I cannot place it back because I have no folder to put it to. Still next to that its strange that if the no password is set to true, it stil doesnt login the server where I can setup databases and that kinda stuff.
I'm lazy and use WinSCP (freebie) to browse my NAS as admin, simply because it's easier to tinker inside the NAS when you're a lazy Windows user like me 75% of the time.
Which PMA addon are you using, WhoCares? or Super_Poussin?
Hi there, thanks for the tip ( the application ) it works very nice. But still. I cannot find the folder of php admin anywhere.
I am using the plugin from readynasextras so that whould be the on from WhoCares right ?
