Dewdman42
May 18, 2012Virtuoso
how to ssh non-root?
Hi all, newb here, I am just playing around with my Ultra2+ before I put any real data on it so that I can try everything out, decide what works and then do a factory default on it. I already fou...
chirpa
May 18, 2012Luminary
You do not void your warranty by using the add-on. The issue comes down to if you SSH in and break your data volume (mounting stuff, formatting, etc), and it is clear to tech support that you broke something, they may ask you to factory default (reset) before they can help you with an issue. For general usage like what you are planning to use, there is no issue.
