penguinny
Oct 26, 2009Aspirant
HP printers firmware uploader
Someone suggested to re-post this here as a request for community add-on. Several inexpensive (=very common) laser printers from HP do not have firmware on board, these include HP LaserJet 1000, 10...
smask
Dec 05, 2009Aspirant
WhoCares? wrote:
Was the printer connected when you installed the addon? If so, unplug the printer from the ReadyNAS, wait a couple of seconds and reconnect it. This should load the correct driver and download the matching firmware to the printer.
-Stefan
No luck. The NAS noticed that no printers were attached and said so. I reattached the printer and the queue reappeared.
I tried to run the /etc/hotplug/usb/hplj1005 (hplj1000) script and it complained that it couldn't find /usr/share/foo2zjs/firmware/sihp1005.dl. There is a firmware, /usr/share/foo2xqx/firmware/sihp1005.img, that the printer didn't like. Some new folders and a copy of my working fw later, the script runs ok without parameters. With "install-usermap" it stops on line 157. The script needs the ex and ed command.
Edit:typo
- Jan 26, 2023Retired_Member
