penguinny
Oct 26, 2009Aspirant
HP printers firmware uploader
Someone suggested to re-post this here as a request for community add-on. Several inexpensive (=very common) laser printers from HP do not have firmware on board, these include HP LaserJet 1000, 10...
crizz187
Mar 16, 2010Aspirant
Ok, I did exactly as stated (without any knowledge of linux) in the guide by Smask, and everything just worked perfectly. It took about 5 min and then my HP 1020 was up and running, printing wireless on Vista and 7 machines. I really appreciate what you did guys. Thank you.
From what I understand its not possible to uninstall EnableRootSSH, so I just used ToggleSSH to turn it off. But is it possible to uninstall APT? And if it was possible, would that in some way disable the printer again?
thanks again
/C
thanks again
/C
- Jan 26, 2023Retired_Member
