penguinny
Oct 26, 2009Aspirant
HP printers firmware uploader
Someone suggested to re-post this here as a request for community add-on. Several inexpensive (=very common) laser printers from HP do not have firmware on board, these include HP LaserJet 1000, 10...
smask
Jul 01, 2010Aspirant
Tradewind25 wrote: This is the first time I have attempted to install an add-on. Any idea what my problem is??
ReadyNAS NVX running RAIDiator 4.2.11
There's your problem. The NVX uses Intel CPUs, Duo and NV+ uses Sparc.
Maybe you can SSH and install foo2zjs from Debian. Check with WhoCares about the procedure to install Debian foo2zjs on your ReadyNAS.
If the foo2zjs package is complete, there will be a tool called "getweb" that will dl the Windows driver and extract the firmware.
getweb <your laserjet model>
You may have to go thru the steps in my long post.
- Jan 26, 2023Retired_Member
