daniele76
Mar 20, 2016Aspirant
Impossible to install Apps (update problem with 6.4.2OS) #26554085
Hello guys! I hope this is the right section for this topic...
I'm using my ReadyNAS with 6.4.2 OS on a NETGEAR ReadyNAS 102. Since a while, it seems to be impossible to install App in the web-ba...
mdgm-ntgr
Mar 20, 2016NETGEAR Employee Retired
Which apps do you currently have installed?
What does your /etc/apt/sources.list look like?
daniele76
Mar 26, 2016Aspirant
Really sorry for the delay, I couldn't use the machine during last week...
I partially solved the problem, fixing a missing library with apt-get install -f: now I'm able to install new apps.
However no changes in the sudo apt-get update problem...
my sources.list:
deb http://apt.readynas.com/packages/readynasos 6.4.2 updates apps main deb http://mirrors.kernel.org/debian wheezy main deb http://security.debian.org/ wheezy/updates main
Thank you very much!
Daniele
