rabidh's avatar
rabidh
iPhone/iPad charging (ReadyNAS Duo/NV+ v2)
If you want to charge with the ReadyNAS (tested on NV+ v2) you’ll have to install the code from here: https://github.com/mkorenkov/ipad_charge/
First off, you need to have installed EnableRootSSH and to have logged in via SSH. Then type:
sudo apt-get install make gcc git libusb-1.0-0-dev
mkdir workspace
cd workspace
git clone https://github.com/mkorenkov/ipad_charge/
cd ipad_charge
make
make install
And the next time you plug your iPad/iPhone into a USB socket on your ReadyNAS, it’ll start charging!
I wonder if this could be packaged up? it'd be a really useful add-on.
1 Reply
  • Interesting software. I could see the need on the iPad, where it draws more current than many USB ports put out by default.
    I already charge my iPhone daily off a ReadyNAS, without any software needed. If I have photo backup enabled (USB Storage tab), I believe it also tries to copy my Camera Roll off also.
ProSupport for Business
