Chris_Dwyer
May 26, 2015Aspirant
Migrate from Egnyte to ReadyCloud
Hi All, We have a RN314 synched with Egnyte using Egnyte Local Cloud. Our need for Egnyte has reduced to a point where we really only need to be able to access our files occasionally when not in t...
mdgm-ntgr
May 27, 2015NETGEAR Employee Retired
I think it should work fairly smoothly.
One of the key advantages of Egnyte is that you get fast speeds from their servers. If your upload is good at your office then hopefully you will still get good speeds.
As for the off-site copy you could get a second ReadyNAS and use ReadyNAS Replicate.
