gksolutions
Sep 13, 2016Aspirant
NAS RN 516 disabled and greyed-out within Replicate
My latest NAS (RN 516), labeled NAS-RDN-NL seems to be disabled and greyed-out within Replicate...? Device Name: NAS-RDN-NL Device Model: ReadyNAS 516 Device Serial: 3C82350N01C41 Firmware:...
- Sep 24, 2016
Updated firmware on the PRO and rebooted the NVX. Both the PRO and the 516 are working with Replicate and am currently running a backup job now. I will try to get the NVX running again in Replicate sometime in Q1 2017. If I run into any issue with it, I'll create a new post specifically for it.
Truly appreciate all your time, patience and guidance, so big thanks again!!
mdgm-ntgr
Sep 13, 2016NETGEAR Employee Retired
You've got a lot of DNS Server addresses configured. Are they correct?
Can you pdate to 6.5.2?: http://kb.netgear.com/app/answers/detail/a_id/31116/~/readynas-os-version-6.5.2
Your logs are flooded with SSH connection attempts. Best not to port forward SSH if you don't need to.
- gksolutionsSep 13, 2016Aspirant
The only DNS IPs should be 86.116.46.20 and 86.116.46.21. The others can/will be removed.
Have also removed forwarding of port 22 on router. Hopefully the attempts were only from yesterday. I was in via SSH yesterday trying to reboot/restart remotely since I couldn't get into Frontview locally (via RDP or Teamviewer to locally attached computer) and it wasn't restarting via RAIDar.
Will update to 6.5.2 once I can get back into Frontview.
...should I also update my ReadyNASRNDP6000v2 to 6.5.2 which is on the same local LAN network?
- mdgm-ntgrSep 14, 2016NETGEAR Employee Retired
If that's running OS6 too then yes you should update it.
- gksolutionsSep 16, 2016Aspirant
I updated the firmware on the RDN516 to 6.5.2 but it status continually shows as 'System starting up...' and I can no longer login to Frontview. I can access the shares via Windows Explorer. My neighbor will not be able to do a hard-boot for me again, so this might have to wait until my return to NL on the 25th September.
...sorry DNS IP should be 84.116.46.20 and 84.116.46.21
