gksolutions
Sep 13, 2016Aspirant
NAS RN 516 disabled and greyed-out within Replicate
My latest NAS (RN 516), labeled NAS-RDN-NL seems to be disabled and greyed-out within Replicate...? Device Name: NAS-RDN-NL Device Model: ReadyNAS 516 Device Serial: 3C82350N01C41 Firmware:...
- Sep 24, 2016
Updated firmware on the PRO and rebooted the NVX. Both the PRO and the 516 are working with Replicate and am currently running a backup job now. I will try to get the NVX running again in Replicate sometime in Q1 2017. If I run into any issue with it, I'll create a new post specifically for it.
Truly appreciate all your time, patience and guidance, so big thanks again!!
gksolutions
...should I also update my ReadyNASRNDP6000v2 to 6.5.2 which is on the same local LAN network?
mdgm-ntgr
Sep 14, 2016NETGEAR Employee Retired
If that's running OS6 too then yes you should update it.
- gksolutionsSep 16, 2016Aspirant
I updated the firmware on the RDN516 to 6.5.2 but it status continually shows as 'System starting up...' and I can no longer login to Frontview. I can access the shares via Windows Explorer. My neighbor will not be able to do a hard-boot for me again, so this might have to wait until my return to NL on the 25th September.
- mdgm-ntgrSep 16, 2016NETGEAR Employee Retired
I have sent you a PM
- gksolutionsSep 24, 2016Aspirant
