Angusmac1
Feb 09, 2014Tutor
Nas won't connect to internet
Hi All. My NAS has stopped connecting to the internet and so i can no longer access it from work. All was fine previously but i have had a BT infinity upgrade (hi speed uk connection) with a new r...
vandermerwe
Feb 09, 2014Master
What are your readynas network settings?
What is the IP address of the router?
Does the router have MAC filtering on and if so is the mac of the readynas on the list?
You are using readynas remote to access the NAS from work I presume?
