Angusmac1
Feb 09, 2014Tutor
Nas won't connect to internet
Hi All. My NAS has stopped connecting to the internet and so i can no longer access it from work. All was fine previously but i have had a BT infinity upgrade (hi speed uk connection) with a new r...
Feb 10, 2014Guru - Experienced User
If you are reaching your NAS reliably from your home equipment, then your static IP address on the NAS is not the problem.
How do you access the NAS when you are at work? Are you using ReadyNAS Remote, your web browser, or an FTP client???
