Angusmac1
Feb 09, 2014Tutor
Nas won't connect to internet
Hi All. My NAS has stopped connecting to the internet and so i can no longer access it from work. All was fine previously but i have had a BT infinity upgrade (hi speed uk connection) with a new r...
Feb 10, 2014Guru - Experienced User
Good catch. A wrong gateway setting could also explain your symptoms. A more common gateway address would be 192.168.1.1.
vandermerwe wrote: ...is the "Default gateway" setting in the nas network settings also 192.168.1.254?
If you ping 192.168.1.254 from a PC, what is the result?
