Angusmac1
Feb 09, 2014Tutor
Nas won't connect to internet
Hi All. My NAS has stopped connecting to the internet and so i can no longer access it from work. All was fine previously but i have had a BT infinity upgrade (hi speed uk connection) with a new r...
Mar 15, 2014Guru - Experienced User
Ok. I'm not seeing a full user guide, so I am not sure if it supports address reservation. You might look through the settings, and see if you can find that feature.
