tarobun
Nov 24, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091.
If it doesn't work after installation, try rebooting.
Not sure if it can be install over the top of super-poussin's version, but if you are planning on uninstalling super-poussin's version then remember to save the torrent files somewhere else first.
To quote myself:
Thanks to super-poussin for the original Transmission add-ons.
Enjoy!
Transmission_2.73.bin - http://www.mediafire.com/?ajpyyc7ujv54o37 no-utp
Transmission_2.75.bin - http://www.mediafire.com/?gbmbhu3hrabf9fe
Transmission_2.76.bin - http://www.mediafire.com/?389i53w9w9rtosm
Transmission_2.77.bin - http://www.mediafire.com/?pm420vuajaim9bz
Transmission_2.80.bin* - http://www.mediafire.com/?5s7dag8ko72doj1
Transmission_2.81.bin* - http://www.mediafire.com/?x4pvvidrgb36df2
Transmission_2.82.bin* - http://www.mediafire.com/?rbctsdae000zoav
Transmission_2.83.bin* - http://www.mediafire.com/?31iul25i0t12qda
Transmission_2.84.bin* - http://www.mediafire.com/?rh5fge4mc8ahzw4
*if the "Upload" button doesn't work or the "Destination folder" field is blank, reload the webpage.
To quote myself:
tarobun wrote: It looks like upgrading from Transmission 2.42 to this Transmission add-on is a no-no. Sounds like there are conflicting configuration that screws up both installs. :( (eg. /c/addons-config)
It seems the best approach is to fully uninstall the old, delete the config directory, and then install this add-on. Once you're on this add-on, updating is straightforward and can be done over the existing version.
Just a fyi - the default download dir is /var/local/Downloads and there is no username and password with this add-on. If you are prompted for them then the old version was not fully uninstalled.
Enjoy!
- spacecrapAspirant
tarobun wrote: spacecrap wrote: I can only change the settings.json file in the 'transmission-deamon' folder... but when I change the name and start + close down transmission nothing changes.
Is there a settings.json in the /addons-config/Transmission/ folder? That's the one you should be changing. The other one is now unused.spacecrap wrote: I cannot copy my old files to the new folder and I don't know what I have to change to reconfigure transmission so my old torrents can be shared again.
Why can't you copy the files to the new folder? Do you get an error?
There are 2 way to get your old torrents back:
1) You'll need to move all the *.torrent files in /addons-config/Transmission/transmission-daemon/torrents to /addons-config/Transmission/torrents and change your download dir to point to the old folder.
2) Edit the /etc/frontview/addons/bin/TRANSMISSION/start.sh and change TRANSMISSION_HOME=/c/addons-config/Transmission to TRANSMISSION_HOME=/c/addons-config/Transmission/transmission-daemon (and also remember to do so each time you upgrade the addon).
Option 1) is the preferable one.
There is a settings.json file in the transmission folder, but this cannot be edited. I tried that without succes.
When I want to copy files it gives the error that the disk is full or protected against copying.
The strange thing is that Transmission was not working correct, but after editting the file in the transmission-daemon folder it did work... so it almost seems that this folder still is used.
I am at work now so I cannot test your option 2, but I will do this this afternoon. I will keep you posted. - spacecrapAspirantso, I'm at home now and tried to acces the settings.json file. The following sign comes up: "acces to *blabla* was denied"
I will now try the second option you advised. - spacecrapAspiranti've opened the transtart.ch file and this came up:
#!/bin/sh
# transmission start by super-poussin
# Variables
# Path to transmission-remote
REMOTE="/usr/local/bin/transmission-remote"
# Options to be passed to transmission-remote
TRANSOPT=" localhost:8181 -n admin:password1"
#LIST=`cat /c/addons-config/Transmission/seeding.txt`
#for ID in $LIST; do
# $REMOTE $TRANSOPT --torrent $ID --start > /dev/null
#done
#LIST=`cat /c/addons-config/Transmission/downloading.txt`
#done
#LIST=`cat /c/addons-config/Transmission/idle.txt`
#done
what do I have to change? - tarobunTutorNope the file is called "start.sh", not the "transtart.sh" (that's the old one).
Change "start.sh" as follows (difference is in bold).
#!/bin/bash
# This should contain necessary code to start the service
export TRANSMISSION_HOME=/c/addons-config/Transmission
export TRANSMISSION_WEB_HOME=/etc/frontview/addons/ui/TRANSMISSION/web
ARGS="-f"
[ -f /c/addons-config/Transmission/settings.json ] || ARGS="$ARGS -a 127.0.0.1,10.0.0.*,192.168.*.* -w /c/media/BitTorrent"
start-stop-daemon --start --chuid nobody:nogroup --umask 0 --nicelevel 19 \
--background --quiet --make-pidfile --pidfile /var/run/TRANSMISSION.pid \
--exec /etc/frontview/addons/bin/TRANSMISSION/transmission-daemon -- $ARGS
To:
#!/bin/bash
export TRANSMISSION_HOME=/c/addons-config/Transmission/transmission-daemon
ARGS="-f"
Also running the following command should make all files under /addons-config read/writable.chown -R nobody.nogroup /c/addons-config
- spacecrapAspirantI cannot find any file that is called start.sh.... :(
maybe a clean install would do the trick?
And I'm starting to feel like a noob, but how do I enter a command line? I tried to find out on the www and ended up with putty icw. rootssh but it seems that the command line you noted has no effect.... (i know I'm missing something... but what) - AlTaiR1AspirantWhen I alter the settings from the web interface; They apply but don't seem to alter the /addons-config/Transmission/settings.json file. Where do these get stored?
- tarobunTutor
spacecrap wrote: I cannot find any file that is called start.sh.... :(
The file should be in /etc/frontview/addons/bin/TRANSMISSION if it's not that the new version has not installed correctly. What version does it say on the ReadyNAS FrontView addon services tab?spacecrap wrote:
If the command was run successfully you should be able to open/edit any files in /addons-config/Transmission -> No more "access denied". - tarobunTutor
AlTaiR wrote: When I alter the settings from the web interface; They apply but don't seem to alter the /addons-config/Transmission/settings.json file. Where do these get stored?
The settings.json file is only saved when the Transmission service stops (via the ReadyNAS FrontView addon services tab) or when the ReadyNAS shuts down. - flamesong1AspirantI have been having a problem which, if I think about it, has only occurred since I upgraded to Transmission v2.8.1 and that is that I am unable to move anything out of the BitTorrent folder or rename anything in it or in subfolders. I am asked for my password which is then apparently rejected as the action is not carried out. If I copy the files to my MacBook, I have the same problem there with the only exception that my password is accepted.
The only way to do anything is to go into Frontview and reset the share's permissions but that needs doing every time because the next time I want to rename or move anything, it happens again.
I have been trying to figure this out for some time now but just realised that, as far as I know, it is only the BitTorrent folder that is affected. I don't see any mention of this issue in the release notes of 2.8.2 so I don't know if this is a known issue or just something which I am experiencing but I am wondering if Transmission is setting the file/folder permissions or maybe it is not doing something it should do.
Can anybody shed some light on this for me as it is driving me insane having to continuously reset permissions. - tarobunTutorI think they changed something in Transmission 2.8x...
What is the umask value in your settings.json file? Can you try it with "umask":0 ?
