tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091.
If it doesn't work after installation, try rebooting.
Not sure if it can be install over the top of super-poussin's version, but if you are planning on uninstalling super-poussin's version then remember to save the torrent files somewhere else first.
To quote myself:
Thanks to super-poussin for the original Transmission add-ons.
Enjoy!
Transmission_2.73.bin - http://www.mediafire.com/?ajpyyc7ujv54o37 no-utp
Transmission_2.75.bin - http://www.mediafire.com/?gbmbhu3hrabf9fe
Transmission_2.76.bin - http://www.mediafire.com/?389i53w9w9rtosm
Transmission_2.77.bin - http://www.mediafire.com/?pm420vuajaim9bz
Transmission_2.80.bin* - http://www.mediafire.com/?5s7dag8ko72doj1
Transmission_2.81.bin* - http://www.mediafire.com/?x4pvvidrgb36df2
Transmission_2.82.bin* - http://www.mediafire.com/?rbctsdae000zoav
Transmission_2.83.bin* - http://www.mediafire.com/?31iul25i0t12qda
Transmission_2.84.bin* - http://www.mediafire.com/?rh5fge4mc8ahzw4
*if the "Upload" button doesn't work or the "Destination folder" field is blank, reload the webpage.
To quote myself:
tarobun wrote: It looks like upgrading from Transmission 2.42 to this Transmission add-on is a no-no. Sounds like there are conflicting configuration that screws up both installs. :( (eg. /c/addons-config)
It seems the best approach is to fully uninstall the old, delete the config directory, and then install this add-on. Once you're on this add-on, updating is straightforward and can be done over the existing version.
Just a fyi - the default download dir is /var/local/Downloads and there is no username and password with this add-on. If you are prompted for them then the old version was not fully uninstalled.
Enjoy!
- tarobunTutor
rybackisback wrote: After updating my ReadyNAS NV+ from Transmission 2.42 to 2.8 Transmission stopped working.
When I put in a torrent file or a magnetic link and press upload nothing happens. I have refreshed the page with no luck.
Try reloading the web page... Ctrl-F5 (Windows) or Cmd-R (Mac).
Not just refresh, you need to reload. - tarobunTutor
Mr_B wrote: Probably a stupid question. Is it update safe? Retains settings, and loaded torrents?
Thank you for your time and effort.
B!
Yep, and yep. - rybackisbackAspirantAfter updating my ReadyNAS NV+ from Transmission 2.42 to 2.8 Transmission stopped working.
When I put in a torrent file or a magnetic link and press upload nothing happens. I have refreshed the page with no luck. I have tried uninstalling and reinstalling still no luck. Now I cant get ver 2.42 to work either. Please Help. My settings.json file is as below:
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1&fileformat=p2p&archiveformat=gz",
"cache-size-mb": 2,
"dht-enabled": true,
"download-dir": "/var/local//Downloads",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 0,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/var/local//Downloads",
"incomplete-dir-enabled": false,
"lpd-enabled": true,
"message-level": 2,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 200,
"peer-limit-per-torrent": 50,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 0,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{96792b9ef294d0262728648b7f397c649983b72bSTOJSxyI",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "",
"rpc-whitelist": "127.0.0.1,10.0.0.*,192.168.*.*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 0,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 18,
"upload-slots-per-torrent": 14,
"utp-enabled": true
} - Mr_BGuideProbably a stupid question. Is it update safe? Retains settings, and loaded torrents?
B! - tarobunTutorUpdated to version 2.80 - dedicated to O. Jonsson (my very first donator! :D)
Changes:
All Platforms- Support renaming a transfer's files and folders
- Remove the most frequent thread locks in libtransmission (ie, fewer beachballs)
- Show the free disk space available when adding torrent
- Faster reading and parsing of local data files
- Better use of the OS's filesystem cache
- Lengthen the prefetch cache for data sent to peers
- Other small speedups
Web Client- Extend the cookie lifespan so that settings like sort order don't get lost
- pugilaresAspirantDoes it mean that it's running, you can access web interface, you can add torrents to download/upload?
If so, there must be something with your network configuration. Are you utilising UPnP in your net? - siecoAspirantI ahve today loaded transmission 2,77 sparc to My ReadyNas Duo, but it wont run any downloads and keeps telling me that it could not connect to the server, help.
- pugilaresAspirantJust upgraded by first making copy of configuration files from 2.42, then uninstall of 2.42, install 2.77, copy configuration files to /c/addons-config/Transmission/ and it seems to work fine! Thank's a lot guys :-)
- pugilaresAspirantThank's a lot :-)
- Mr_BGuide
Trukhin wrote: Hmm... Build size reduced from ~20 MB to ~2MB (2.42 -> 2.76)? tarobun wrote: Yep, that's the file size with all debug symbols stripped.
B!
