yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help.
1. If you are in User or Domain security mode, and you don't have "public" or "guest" access enabled for the [media] share, you will need to specify a login and password to connect from the ReadyNAS Photos desktop software. The login and password should be what you would normally use to connect to the [media] share.
2. If you are in Share security mode, and you have a password set for the [media] share, when connecting from the ReadyNAS Photos desktop software, leave the login field blank, and enter the share password.
3. If you are in User or Domain security mode, and you are an account on the ReadyNAS with the same user name but a different password as what you are using on your PC, you will need to change the password to be the same.
4. Make sure [media] share has read/write privileges over CIFS.
5. If you have installed a pre-release version of RAIDiator that had ReadyNAS Photos support (shame on you since we never really released it ;-) ), and you're having problems with the READYNASPHOTOS database, you will need to remove the ReadyNAS Photos add-on, and re-install the add-on from here.
- mullinsworldAspirantI just setup my ReadyNAS Duo. RAIDar 4.1.3 - downloaded ReadyNAS Photos 2.2. When I launch the app it opens the brower to a localhost.com and hangs. Any ideas for this total newbie?
Thanks - shumbiesAspirantSpot on Minerva,
Really appreciate your help, thank you.
All systems GO! :D
Cheers
Gavan - shumbiesAspirantHi Minerva,
Thanks for the prompt response.minerva wrote: Do you see the ReadyNAS Photos icon in the System tray ?
Nominerva wrote: Do you have Javascript enabled in your browser ?
Yesminerva wrote: Can you copy and paste here what running cmd
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ping localhost
Pinging shumbies-PC [::1] from ::1 with 32 bytes of data:
Reply from ::1: time<1ms
Ping statistics for ::1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms - minervaAspirantHi Gavan,
Can you copy and paste here what running cmdping localhost
return ?
-minerva - shumbiesAspirantHello,
Newbie Photo dude here!
I am having trouble installing the ReadyNAS Photo application on my PC with the following NAS.
Model: ReadyNAS Duo [X-RAID]
Firmware: RAIDiator 4.1.5 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
I have enabled the ReadyNAS Photo on my NAS, and when I go to install the software and the last webpage comes up I get:
Failed to Connect
The connection was refused when attempting to contact localhost.
Though the site seems valid, the browser was unable to establish a connection.
* Could the site be temporarily unavailable? Try again later.
* Are you unable to browse other sites? Check the computer's network connection.
* Is your computer or network protected by a firewall or proxy? Incorrect settings can interfere with Web browsing.
The address in the Browser is http://localhost/readynas
Tried a number of times...
What am I missing??
Any help much appreciated.
Gavan
" - minervaAspirantHi wobo,
ReadyNAS Photos cannot connect to the NAS over the Internet. NAS has to be in the same LAN as the PC from which you are using ReadyNAS Photos.
-minerva - wobo1AspirantHi!
Trying to make ReadyNAS Photos on my ReadyNAS Dou available externally.
That means I will be able to update albums and such things from anywhere using my laptop and an internet connection.
Trying to connect to it at work right now. Get invalid credentials however I try.
I have the latest ReadyNAS photos addons, it is online.
Got the latest ReadyNAS Photos desktop application.
Dunno what to do now.
Got the media share so it have read/write with CIFS.
It also is http/s read only with exception to my account which have allowed user access.
Do you need to configure router/firewall in some way that I don't know?
//wobo - minervaAspirantRe: Duplication of photos
Please see my answer to the same question here : viewtopic.php?f=58&t=26040 - minervaAspirantRe : User offline problem :
* Make sure you have the latest version of the ReadyNAS Photos Add on installed on the your ReadyNAS. You can download the latest version of the Add on here : http://www.readynas.com/?page_id=617. If you did not have the latest version of the Add-on upgrade to this version.
* After upgrading to the new version of add-on, if you are still experiencing the user offline problem the please check the following.
Is your NAS setup with DHCP IP or Static IP? If static, do you have a Gateway and DNS setup under Network>Global Settings.
Do you have System>Alerts Contacts setup as well, and receive those (you can Send a Test message there as well)?
Also, does the 'Check for Updates' under System>Update work, or report connection problems?
These things will help us narrow down any connection issues your NAS has with reaching the Internet.
For the shared photos to be accessible, your ReadyNAS should stay connected to the internet.
-minerva
