StuBarrett1
Jun 17, 2019Aspirant
ReadyNAS Pro will not power on
Please help. I have a ReadyNAS raid storage unit Business/Pro model RNDP6000 with 6 disk slots. I returned from vacation to find my AC had quit and the house was very warm. I used the fron...
- Jun 18, 2019
StuBarrett1 wrote:
... the CMOS battery was pulled during the debug process so I lost the CMOS settings. ... Is that equivalent to a "factory reset"?
The CMOS battery only keeps the real time clock ticking - which is needed for the power schedule feature.
So you haven't lost anything.
Marc_V
Jun 17, 2019NETGEAR Employee Retired
Welcome to the Community!
If you are looking for a new unit, It would be best if you can get a ReadyNAS OS 6 Unit like the RN426, RN526 or RN626. You can actually get your Data back by following this procedure.
Alternatively, you can check out a refurbished RNDP6000 on a reasonable price.
HTH
Regards
- StephenBJun 17, 2019Guru - Experienced User
Try removing the disks (labelng by slot), and see if the unit powers up with a no disks status. Also check the status with RAIDar ( https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar )
If the unit does power up diskless, then something is corrupted on the disks.
If it doesn't, then the problem is likely the power supply (which can be replaced if you like).
- StuBarrett1Jun 17, 2019Aspirant
Thanks, while I'm not sure if I want to replace the power supply juet yet, can you point me to a plug-in replacement source?
Thanks, stu
It's an sfx supply - the original was a Seasonic SS-300SFD.
You likely won't find a new one, but there are a couple of other options:
You might also need a short ATA extender cable (4 inches should be enough).
This post was focussed on changing the CPU fan, but it should give you some idea of the steps needed to replace the supply: https://community.netgear.com/t5/New-ReadyNAS-Users-General/ReadyNAS-Pro-Replace-CPU-Fan/td-p/940499
