DaveHartley
Dec 22, 2017Follower
ReadyNas Remote and Windows 10 (again)
I'm trying to get my old (but reliable and expanadable) RND4000 V1 working with remote access and windows 10. All the information I can find relates to https://community.netgear.com/t5/Legacy-NETGE...
Dec 22, 2017Guru - Experienced User
Netgear took down the Remote service at the end of September 2017, so that option is no longer available to you.
You can either use port forwarding (FTPS) + DDNS, or a VPN (OpenVPN, ZeroTier) for remote access. The VPN would be implemented outside the NAS (on a PC or router).
- Jul 08, 2018Retired_Member
