jwr11's avatar
jwr11
ReadyNAS remote install problems
Hello,
I am unable to install the ReadyNAS remote software on a PC running Windows 7.
I am guessing the problem is the leafnetworks adapter. I also tried doing a manual install of the adapter with no luck as well. I tried with the AV turned off and in SAFE mode.
Thanks in advance for your help.
Install Info:
Create folder: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NETGEAR ReadyNAS
Output folder: j:\NETGEAR ReadyNAS\Remote\bin
Create shortcut: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NETGEAR ReadyNAS\\ReadyNAS Remote.lnk
Windows Version is 7
Output folder: C:\Windows\system32
Output folder: C:\Windows\system32\drivers
Output folder: j:\NETGEAR ReadyNAS\Remote\adapter
Extract: FwHookDrv.sys... 100%
Extract: fwleaf.cat... 100%
Extract: fwleaf.sys... 100%
Extract: fwleafm.inf... 100%
Extract: fwleafp.inf... 100%
Extract: leafnets.inf... 100%
Extract: leafnets.sys... 100%
Extract: tap.cat... 100%
Output folder: j:\NETGEAR ReadyNAS\Remote\adapter\x64
Extract: DataModelBase.dll... 100%
Extract: FileShare.xml... 100%
Extract: Interop.EventSystemLib.dll... 100%
Extract: Interop.NetFwTypeLib.dll... 100%
Extract: Interop.SensEvents.dll... 100%
Extract: LeafFolder.ico... 100%
Extract: Libnet.dll... 100%
Extract: PacketRoutingPlugin.dll... 100%
Extract: ReadyNASRemote.exe... 100%
Extract: ReadyNASRemote.exe.config... 100%
Extract: SetAdapterHidden.vbs... 100%
Extract: WindowsMediaShare.xml... 100%
Extract: XBoxShare.xml... 100%
Extract: addLeaf.vbs... 100%
Extract: gacutil.exe... 100%
Extract: hstorage.lfn... 100%
Extract: lnSidLibrary.dll... 100%
Extract: lnThreadPool.dll... 100%
Extract: lnadptrcnfg.dll... 100%
Extract: lnadptrcnfgx64.dll... 100%
Extract: lncomservice.dll... 100%
Extract: lninitadapter.dll... 100%
Extract: lnmodel.dll... 100%
Extract: lnp2p.dll... 100%
Extract: lnp2padapter.dll... 100%
Extract: lnp2pclient.dll... 100%
Extract: lnp2penc.dll... 100%
Extract: lnp2pfilter.dll... 100%
Extract: lnp2pnative.dll... 100%
Extract: lnp2pnotification.dll... 100%
Extract: lnpluginmngr.dll... 100%
Extract: lnprotocolhandler.dll... 100%
Extract: lnregasm.exe... 100%
Extract: lnresources.dll... 100%
Extract: lnscrunner.exe... 100%
Extract: lnshplbr.dll... 100%
Extract: lnshrcontainer.dll... 100%
Extract: lnshrmngr.dll... 100%
Extract: lnutils.dll... 100%
Extract: logo.ico... 100%
Extract: msvcr71.dll... 100%
Extract: one.vbs... 100%
Extract: options.config... 100%
Extract: packet.dll... 100%
Extract: pthreadVC.dll... 100%
Extract: setp2padapterip.dll... 100%
Extract: svcutil.dll... 100%
Extract: wpcap.dll... 100%
Output folder: j:\NETGEAR ReadyNAS\Remote\bin\plugins
Output folder: j:\NETGEAR ReadyNAS\Remote\bin\plugins\list
Output folder: j:\NETGEAR ReadyNAS\Remote\docs
Output folder: j:\NETGEAR ReadyNAS\Remote\docs\license
Extract: license.txt... 100%
Output folder: j:\NETGEAR ReadyNAS\Remote\docs\release notes
Extract: Release Notes.txt... 100%
Installing network adapter leafnets.sys (amd64)...
No devices were removed.
Device node created. Install is complete when drivers are installed...
Updating drivers for leafnets from j:\NETGEAR ReadyNAS\Remote\adapter\x64\leafnets.inf.
lnadptrcnfgx64.dll failed.
Done
Adjusting network adapter (amd64)...
ProSupport for Business
