augur
Apr 10, 2024Apprentice
ReadyNAS Ultra 6 - Front View broken
Hi,
I bought a broken ReadyNAS Ultra 6 and reinstalled the OS. This fixed the boot issues but after installing discs I cannot fully connect to front view to prepare e.g. an update to ReadyOS6.
Tried to connect with Edge and also an old Internet Explorer but both shows and empty frontview with a JavaScript error. Any ideas how to solve this? Or prepare the update without a working frontview?
Cheers,
Nils
Does RAIDar tell you what firmware is installed on the NAS?
- augurApprentice
I think the encrypted serial (VPD file) on the internal disc is broken and not recovered by installing a new firmware. That's leads into the broken Frontview.
Solved: ReadyNAS Ultra 6 missing model name and serial num... - NETGEAR Communities
Marc_V I do not know if you are still there but see many posts you helped getting the VPD back.
It could be the VPD - a screenshot from RAIDar would be helpful in figuring that out.
Though I believe a browser incompatibility can also cause this particular symptom, so it is possible that the VPD is ok, and the issue is that the Ultra is running really old firmware.
He's no longer with Netgear. I don't think the current mods have access to the tool needed to rebuild the VPD. They certainly haven't offered to rebuild it for someone for a long time.
