Bob94301's avatar
Jan 21, 2021
Removing Readynas Remote AND Leaf Netwroks
I have a DUO that works flawlessly for me. However, in an odd click discovered ReadyNas Remote 1.6.5.18 no longer works. That's ok. But the questions are:
If I remove ReadyNas Remote from control panel, will it also remove the Leaf Newtwork adapter?
If not, how to remove the Leaf Adapter?
Any risk of injury to other Ethernet connection, wireless connections or mapped drives to the NAS? Just want to be very sure.
Thanks!
  • It's been a long time since I had Remote installed on a PC - but I think uninstalling it there should remove the Leaf VPN as well.
  • StephenB's avatar
    Bob94301 wrote:
    If I remove ReadyNas Remote from control panel, will it also remove the Leaf Network adapter?
    The VPN service will still be present in the system, but it only runs if Remote is running.
    You could do with SSH I guess. Not something I've felt the need to do, so I don't know if there are side effects if it is missing.
    But obviously doing an OS reinstall, etc would just add it back.
    • Bob94301's avatar
      Bob94301
      Guide
      Thanks, but we must be talking about two different things. Leaf Networks runs in Windows and always runs regarless of whether ReadyNas Remote runs or not. Neiother of these are on the NAS.
      • Bob94301's avatar
        Bob94301
        Guide
        Ahhh, OK. There are two parts. One on the NAS and one as a Windows CLient. Its the windows clinet and Winodws Network Adapter I wish to remove.
ProSupport for Business
