coreyleap
Jun 27, 2016Aspirant
Replicate not working error -50 . Services Offline in Cloud tab on source unit.
I am trying to get an offsite backup for our NAS to an offsite location but am having serious issues. Source NAS is a ReadyNas 314 running latetst firmware 6.5.1 and the ofdfsite unit is a ReadyNas 2...
BrianL2
Jun 29, 2016NETGEAR Employee Retired
Hi coreyleap,
Welcome to the community!
It is likely that your Source ReadyNAS is not connecting to the internet properly or maybe both of them. Have DNS 8.8.8.8 added in both NAS units and if this won't fix the problem, consider setting up port forwarding using the port 6XXX under the ReadyCLOUD->Settings page.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
coreyleap
Jul 11, 2016Aspirant
I have got googles dns servers set at both ends so not that. "consider setting up port forwarding using the port 6XXX under the ReadyCLOUD->Settings page." What ports do I open for this and where do I find this exactly and do I need to setup something on my router also to make this works properly, if so which servioces do i need to open on the router firewall.
- StephenBJul 11, 2016Guru - Experienced User
The troubleshooting link is http://kb.netgear.com/app/answers/detail/a_id/25089/~/readynas%3A-replicate-troubleshooting
See pages 15-16 in http://www.downloads.netgear.com/files/GDC/READYNAS-COMMON/ReadyNAS%20Replicate%20UM_10Jul2013.pdf to see how to configure the incoming port. You then forward that port in the firewall.
