volpone's avatar
volpone
Ruby addons to install Redmine Project Management ?
Hello all,
I'm looking a project management software to run from my ReadyNas Pro Pioneeer (x86).
Redmine, http://www.redmine.org/, is such a very good tool but requires Ruby framework to run http://www.ruby-lang.org/en/.
My Linux skills is not sufficient to install Ruby even if debian package intallation and integration procedure exists:
- Debian package: http://packages.debian.org/source/etch/ruby1.8.
- Apache2: Integration: http://www.howtoforge.com/ruby_on_rails_debian_etch
Any Addons to do so ?
Regards
  • No add-ons at this time, but should be possible via SSH access.
    # apt-get update; apt-get install ruby1.8
  • Hi volpone,
    I'm looking for project support for my Readynas as well. Did you succeed in getting the redmine software running?
  • Christiaan wrote:
    Hi volpone,
    No Christiaan,
    I did'nt even tried to install ruby and all the stuff needed ... seems complex.
    However i'm still interested if somobody had experiences running redmine or another project management tool.
    Regards
    Up
  • volpone wrote:
    Christiaan wrote:
    Hi volpone,
    No Christiaan,
    Regards
    hi,
    can you give me an overview what else need to be installed? (ruby installled just installed)
    thx
ProSupport for Business
