mudgetheotter
Apr 22, 2011Aspirant
SABnzbd Completed downloads file permissions
I recently purchased a ReadyNAS Duo to replace my QNAP TS-201. I have just about managed to get the hang of how permissions work. The only major issue I currently have is with SABnzbd. The add-on itse...
Uberrabbit
Apr 26, 2011Aspirant
Thanks!
I had the same problem to, thought it was my own problem because I set it to other dir's and was setting up all kind of permissions solutions I found on the board aswell.
Maybe its a good idea to put it in the tutorial part maybe more people get the problem.
