mudgetheotter
Apr 22, 2011Aspirant
SABnzbd Completed downloads file permissions
I recently purchased a ReadyNAS Duo to replace my QNAP TS-201. I have just about managed to get the hang of how permissions work. The only major issue I currently have is with SABnzbd. The add-on itse...
WhoCares_
May 11, 2011Mentor
dcl! wrote: Yes, would be a good idea to add to the tutorial.
Actually it is mentioned, although just in a single sentence.
dcl! wrote: Because it's confusing (for me, dummy) that the settings of sabnzbd overrule the setting of the share (media= read/write for all).
It doesn't. The thing is that by setting the Share access, you simply allow one/some/all users to do something. The users then can decide to just use a subset of what you were initially allowing. So if a share is shared to be r/w for everyone, a user can still create a file with readonly access. That's nothing special but just the way access permissions on Unix like systems work - and actually the same is true for Windows, too.
dcl! wrote: I still have to log on as admin to delete a file though - the "777" permission only helps to be able to read the file as user.
That's rather strange, I suggest you check your media share's settings again. There should be an Advanced Option to allow other users than the owner to remove files.
-Stefan
