mudgetheotter
Apr 22, 2011Aspirant
SABnzbd Completed downloads file permissions
I recently purchased a ReadyNAS Duo to replace my QNAP TS-201. I have just about managed to get the hang of how permissions work. The only major issue I currently have is with SABnzbd. The add-on itse...
WhoCares_
Nov 27, 2011Mentor
How did you create the Downloads folder in the /c/media share directory and what are the permission settings of that directory? This sounds like the directory was created either manually or at least using some permission settings that lead to the effect you describe.
-Stefan
-Stefan
