mudgetheotter
Apr 22, 2011Aspirant
SABnzbd Completed downloads file permissions
I recently purchased a ReadyNAS Duo to replace my QNAP TS-201. I have just about managed to get the hang of how permissions work. The only major issue I currently have is with SABnzbd. The add-on itse...
sloflo
Nov 27, 2011Aspirant
Yes I had set 777 when I created the Downloads/Complete folder.
I activated the following option:
Set ownership and permission for existing files and folders in this share to the above settings. This option is useful in cases where you are changing security levels and need to workaround file access problems.
As a result I can browse the folder, I tested with a new download and I can access it. :D
Unfortunatly the files I downloaded previously at this exact same spot are not visible... when I check in sabnzbd, the download is completed and the path is the one I am looking into... is there a way to get rid of the file throught sabnzbd?
