linusdunkers
Jul 22, 2012Aspirant
"Snapshot initialization failed" error every time
Please help me! I have paid a lot of money for two units with disks and licenses to run ReadyNas Replicate and I can't get it to work properly! I get the same error message every time I try to use th...
linusdunkers
Jul 23, 2012Aspirant
Today I tested to create a backup job making a backup in the other direction (from my backup nas to my main nas).
It seemed to work just fine. I cancelled the backup since I don't want that backup but it gave me hope that there might be a solution to this problem.
[2012-07-24 05:17:52] [Info] Starting backup job "bu_nas BU"
[2012-07-24 05:17:52] [Info] Replicate addon version: 1.1.3 build R1
[2012-07-24 05:17:52] [Info] Create target folder: /c/backup/bu_nas BU
[2012-07-24 05:17:53] [Info] Locking target folder: /c/backup/bu_nas BU
[2012-07-24 05:17:54] [Info] Making full backup
[2012-07-24 05:17:54] [Info] p2p connect to nas-A0-63-3F in 761509 network
[2012-07-24 05:17:59] [Info] Connection method: 2
[2012-07-24 05:17:59] [Info] LAN connection available
[2012-07-24 05:17:59] [Info] Get LAN credentials
[2012-07-24 05:17:59] [Info] Sending task to source device
[2012-07-24 05:17:59] [Info] Awaiting task report
[2012-07-24 05:18:00] [Info] Received success report
[2012-07-24 05:18:00] [Info] Using LAN connection
[2012-07-24 05:18:00] [Info] Initializing snapshot on source device
[2012-07-24 05:18:00] [Info] Sending task to source device
[2012-07-24 05:18:01] [Info] Awaiting task report
[2012-07-24 05:18:04] [Info] Received success report
[2012-07-24 05:18:04] [Info] Snapshot initialization finished
[2012-07-24 05:18:04] [Info] Creating system config backup
[2012-07-24 05:18:04] [Info] Sending task to source device
[2012-07-24 05:18:04] [Info] Awaiting task report
[2012-07-24 05:18:14] [Info] Received success report
[2012-07-24 05:18:14] [Info] Copy in progress
[2012-07-24 05:21:12] [Error] Job cancelled
[2012-07-24 05:21:12] [Info] Deinitializing snapshot on source device
[2012-07-24 05:21:13] [Info] Sending task to source device
[2012-07-24 05:21:13] [Info] Awaiting task report
[2012-07-24 05:21:15] [Info] Received success report
[2012-07-24 05:21:15] [Info] Snapshot deinitialization finished
[2012-07-24 05:21:15] [Info] p2p disconnect with nas-A0-63-3F in 761509 network
[2012-07-24 05:21:16] [Info] Unlock target folder: /c/backup/bu_nas BU
[2012-07-24 05:21:16] [Info] Job finished
I also tested the real System backup with the same result as earlier, takes about 13 seconds to fail.
[2012-07-24 05:16:18] [Info] Starting backup job "nas BU"
[2012-07-24 05:16:18] [Info] Replicate addon version: 1.1.3 build R1
[2012-07-24 05:16:18] [Info] Locking target folder: /c/backup/nas BU
[2012-07-24 05:16:20] [Info] Resume source is "/c/backup/nas BU/2012-07-22 20-54 (failed)/data"
[2012-07-24 05:16:20] [Warning] Backup item "/c/backup/nas BU/2012-07-22 20-54 (failed)/data/c" not found
[2012-07-24 05:16:20] [Info] p2p connect to nas-A0-A1-AF in 757198 network
[2012-07-24 05:16:26] [Info] Connection method: 2
[2012-07-24 05:16:26] [Info] LAN connection available
[2012-07-24 05:16:26] [Info] Get LAN credentials
[2012-07-24 05:16:26] [Info] Sending task to source device
[2012-07-24 05:16:26] [Info] Awaiting task report
[2012-07-24 05:16:27] [Info] Received success report
[2012-07-24 05:16:27] [Info] Using LAN connection
[2012-07-24 05:16:27] [Info] Initializing snapshot on source device
[2012-07-24 05:16:27] [Info] Sending task to source device
[2012-07-24 05:16:27] [Info] Awaiting task report
[2012-07-24 05:16:29] [Error] Received failed report
[2012-07-24 05:16:29] [Error] Snapshot initialization failed
[2012-07-24 05:16:29] [Info] Deinitializing snapshot on source device
[2012-07-24 05:16:29] [Info] Sending task to source device
[2012-07-24 05:16:29] [Info] Awaiting task report
[2012-07-24 05:16:30] [Info] Received success report
[2012-07-24 05:16:31] [Info] Snapshot deinitialization finished
[2012-07-24 05:16:31] [Info] p2p disconnect with nas-A0-A1-AF in 757198 network
[2012-07-24 05:16:31] [Info] Unlock target folder: /c/backup/nas BU
[2012-07-24 05:16:31] [Info] Job finished
I removed all backup jobs and all the folders they created on both my nas-units. I also restarted both nas-units and created one new System backup job with a new name.
But it didn't work...
[2012-07-24 06:04:37] [Info] Starting backup job "FULL NAS BU"
[2012-07-24 06:04:37] [Info] Replicate addon version: 1.1.3 build R1
[2012-07-24 06:04:37] [Info] Create target folder: /c/backup/FULL NAS BU
[2012-07-24 06:04:37] [Info] Locking target folder: /c/backup/FULL NAS BU
[2012-07-24 06:04:38] [Info] Making full backup
[2012-07-24 06:04:38] [Info] p2p connect to nas-A0-A1-AF in 761563 network
[2012-07-24 06:04:43] [Info] Connection method: 2
[2012-07-24 06:04:43] [Info] LAN connection available
[2012-07-24 06:04:43] [Info] Get LAN credentials
[2012-07-24 06:04:43] [Info] Sending task to source device
[2012-07-24 06:04:44] [Info] Awaiting task report
[2012-07-24 06:04:45] [Info] Received success report
[2012-07-24 06:04:45] [Info] Using LAN connection
[2012-07-24 06:04:45] [Info] Initializing snapshot on source device
[2012-07-24 06:04:45] [Info] Sending task to source device
[2012-07-24 06:04:45] [Info] Awaiting task report
[2012-07-24 06:04:49] [Error] Received failed report
[2012-07-24 06:04:49] [Error] Snapshot initialization failed
[2012-07-24 06:04:49] [Info] Deinitializing snapshot on source device
[2012-07-24 06:04:49] [Info] Sending task to source device
[2012-07-24 06:04:50] [Info] Awaiting task report
[2012-07-24 06:04:53] [Info] Received success report
[2012-07-24 06:04:53] [Info] Snapshot deinitialization finished
[2012-07-24 06:04:53] [Info] p2p disconnect with nas-A0-A1-AF in 761563 network
[2012-07-24 06:04:54] [Info] Unlock target folder: /c/backup/FULL NAS BU
[2012-07-24 06:04:54] [Info] Job finished
