linusdunkers
Jul 22, 2012Aspirant
"Snapshot initialization failed" error every time
Please help me! I have paid a lot of money for two units with disks and licenses to run ReadyNas Replicate and I can't get it to work properly! I get the same error message every time I try to use th...
linusdunkers
Aug 01, 2012Aspirant
It is working fine after disabled snapshots, the first backup took about one week to finish, below is the log:
[2012-07-28 23:26:22] [Info] Starting backup job "System Backup"
[2012-07-28 23:26:22] [Info] Replicate addon version: 1.1.3 build R1
[2012-07-28 23:26:22] [Info] Locking target folder: /c/backup/System Backup
[2012-07-28 23:26:23] [Info] Resume source is "/c/backup/System Backup/2012-07-28 23-21 (failed)/data"
[2012-07-28 23:26:23] [Warning] Backup item "/c/backup/System Backup/2012-07-28 23-21 (failed)/data/c" not found
[2012-07-28 23:26:23] [Info] p2p connect to nas-A0-A1-AF in 775674 network
[2012-07-28 23:26:28] [Info] Connection method: 2
[2012-07-28 23:26:28] [Info] LAN connection available
[2012-07-28 23:26:29] [Info] Get LAN credentials
[2012-07-28 23:26:29] [Info] Sending task to source device
[2012-07-28 23:26:29] [Info] Awaiting task report
[2012-07-28 23:26:30] [Info] Received success report
[2012-07-28 23:26:30] [Info] Using LAN connection
[2012-07-28 23:26:30] [Info] Initializing snapshot on source device
[2012-07-28 23:26:30] [Info] Sending task to source device
[2012-07-28 23:26:30] [Info] Awaiting task report
[2012-07-28 23:26:51] [Info] Received success report
[2012-07-28 23:26:51] [Warning] Snapshot not requested. Backup can be inconsistent
[2012-07-28 23:26:51] [Info] Snapshot initialization finished
[2012-07-28 23:26:51] [Info] Creating system config backup
[2012-07-28 23:26:51] [Info] Sending task to source device
[2012-07-28 23:26:52] [Info] Awaiting task report
[2012-07-28 23:27:02] [Info] Received success report
[2012-07-28 23:27:02] [Info] Copy in progress
[2012-08-01 09:08:33] [Info] Copy finished
[2012-08-01 09:08:33] [Info] Deinitializing snapshot on source device
[2012-08-01 09:08:34] [Info] Sending task to source device
[2012-08-01 09:08:45] [Error] Unable to send task
[2012-08-01 09:08:45] [Error] Snapshot deinitialization failed
[2012-08-01 09:08:45] [Info] p2p disconnect with nas-A0-A1-AF in 775674 network
[2012-08-01 09:08:45] [Info] Unlock target folder: /c/backup/System Backup
[2012-08-01 09:08:45] [Info] Job finished
