rogercaplan
Dec 02, 2011Aspirant
ssh for Duo v2?
Is it possible to enable root ssh for the duo v2? Uploading EnableRootSSH_1.0-x86.bin results in the error message "Architecture is bad".
mdgm-ntgr
Dec 20, 2011NETGEAR Employee Retired
Did you look at the link at the end of my first post in this thread? That links to the ARM add-on which is the one you can install on the Duo v2.
