rogercaplan
Dec 02, 2011Aspirant
ssh for Duo v2?
Is it possible to enable root ssh for the duo v2? Uploading EnableRootSSH_1.0-x86.bin results in the error message "Architecture is bad".
mdgm-ntgr
Jun 01, 2012NETGEAR Employee Retired
If you can't make the settings through Frontview or editing the cron script you'll have to live with it or do your backups manually via the command line or your own custom shell script. If the backups are between the v1 and the v2 you could simply run the backup jobs on the v1.
