rogercaplan
Dec 02, 2011Aspirant
ssh for Duo v2?
Is it possible to enable root ssh for the duo v2? Uploading EnableRootSSH_1.0-x86.bin results in the error message "Architecture is bad".
jleinbach
Jun 01, 2012Aspirant
Just so i'm sure I understand, this is a change between v1 and v2? My backup is going from the ReadyNAS to ibackup using rsync. Ibackup's rsync server chokes on one of the parameters passed by the ReadyNAS. My solution with the v1 box was to just change its backup script so that it no longer included that parameter. Worked like a charm and I could still manage everything via the ReadyNAS interface (helpful because things like sending email notifications are all handled, etc). I want to do the same thing now with the v2 box (it is replacing the v1 box which now has a non-drive related hardware issue). It sounds like that will no longer be possible. Is that really the case? Thanks again for the education.
