Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also.
It`s very outdated now... :oops:
Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue.
Trying to figure out how to do it myself, but it would be much easier if the author would update whole package.
- BascyAspirantInstalled your security.php
removed secure_conn setting
charts are now working fine, but when i click on server or settings, i get the login-screen even though i havent set a username/password in the settings
BTW: i see no logfiles in the logs subfolder of Loadavg ... where are they saved?? - EtzAspirant
Bascy wrote: Installed your security.php
logs should be in /c/webroot/loadavg/logs
For authentication, you should set user and password. Because its a GUI for modifying configuration and its always password protected ;) - BascyAspirantSet the username and password and rtp password in the settings file
Enter my credentials in the log screen, but i always get the charts screen, even when i click on server and log in - EtzAspirant
Bascy wrote: Set the username and password and rtp password in the settings file
Hmm on my box its started to work fine after those modifications...
Will check when I get home, I have SSH access to my box now, but not WebServer access :lol: - BascyAspirantAlso the phpsysinfo screen only showns a nice green background with the message "Loading please wait"
- EtzAspirant
Bascy wrote: Also the phpsysinfo screen only showns a nice green background with the message "Loading please wait"
You could update It manually to 3.0.10 and it starts to work...
Only dont overwrite plugins folder, or you have to do lot of manual adjustments later... :wink:Etz wrote: Also I guess phpsysinfo needs to be updated to 3.0.10, because DUO doesnt have "horsepower" to compress that amount of data and it times out and never loads. Newer versions have option to disable compression in config file. Etz wrote: Also could you consider upgrading (or downgradeing to old version again) phpsysinfo to 3.0.10 and disabling JS compression in config file :roll:
Read previous posts in this thread :P
PS: It wont show you RAID status, if youre using X-RAID, because cat /proc/mdstat wont output anything about RAID level, because its NetGear proprietary and not standard. - BascyAspirantOk, got some info now, only missing Smart info
but have to look at that later .. gotto do some actual work now :-0
thanks for the support - EtzAspirant
Bascy wrote: Ok, got some info now, only missing Smart info
For SMART info to display properly, modify SMART plugin configuration file: SMART.config.php (line 34)
(located at /c/webroot/loadavg/phpsysinfo/plugins/SMART/)
Issue is DUO doesn`t have /dev/hda & /dev/hdb as defined in there (at least if youre using X-RAID).
replace those with /dev/hdc & /dev/hde (or whatever your HDD device are, you can check it with fdisk -l) and it starts to display that information ;) - BascyAspirantReplaced the devices in the SMART.config.php, now im getting the following error:
DataTables warning (table id = 'Plugin_SMART'): Attempted to initialise DataTables on node which is not a table:DIV
Don't know which system is generating the error (php, xml, SMART, browser) I'm using Chrome
Can anybody help?
Updated the SMART.js script from the sourceforge repository and now its working! - EtzAspirant
Bascy wrote: SolvedUpdated the SMART.js script from the sourceforge repository and now its working!
I accidentally overwrited plugins folder, so I had to adjust all manually. So there are more changes in plugins also then.
Best of all, it seems to be working in all aspects now :D
Too bad, I havent figured out how to build it as binary addon, but im begginning to understand that process, so I will give it atry in this weekend. :neener:
