omer1143's avatar
omer1143
Teaming support for ReadyNAS Pro Pioneer with 4.2.17
Hello,
I sucessfully run my ReadyNAS Pioneer Pro under 4.2.15 and I'm using the teaming add-on provided by super-poussin. The new firmware release 4.2.17 provides a couple of improvements and so I'm planning to upgrade to that one. But before I'm going to do that, I'd like to know, if somebody in the community has already been able to install the teaming community add-on of super-poussin.
This add-on is a great piece of software and together with a managed CISCO switch and a dual port card on my Windows 7 machine, I get transfer rates of 100MB/s. I don't want to downgrade to a slower solution.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    One of the problems is that each firmware update can potentially change the way teaming is handled, so it might not be long after a new add-on's ready (if it can be done) before a firmware update breaks it again.
  • Just an update for the group: I did take the risk and upgrade to 4.2.17. Teaming still works. Super-poussin, no worries, you don't have to spend more time on this. Team v2.1 with 802.3ad and jumbo frames workes great with me.
