Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process crashed or stopped in some way. I can restart the Transmission but as soon as I try to do something, e.g., deleting a torrent, Transmission crashes again. I've enabled DHT but shouldn't the Duo have enough power to run Transmission anyway? Or can't I expect this add-on to run on this relatively weak system? I haven't upgraded the RAM either.
- JarnoGGuideYou can not change the password using the webinterface, you will have to edit the settings.json file.
Stop the Transmission add-on and open settings.json
Change "rpc-password" and "rpc-username" to whatever you want. The password should be between the "" and not start with {.
After saving the file, start the Transmission add-on again.
It will automatically change the plain-text password in the settings file to a encoded one and save that.
Make sure to set "rpc-authentication-required" to true or it will not use the username/password - PiddePAspirantI'm having trouble getting Transmission 2.40 to work on an Ultra 2. Regardless of which setting file I use (I've tried the settings files that's been posted) I get "permission denied opening folder XXX" after a while and the transfer is aborted.
Do I need to makesome chmod-changes for it to work?
