Allard72
Jun 10, 2016Aspirant
0x80070035 fault after upgrade 6.5
After upgrade to 6.5 of My readynas Duo v2, No access to any NAS folders Access via Readycloud or connecting admin via IP is no problem. Directly from computers with Windows 7 and 10 or my Home ...
Allard72
Jun 23, 2016Aspirant
No, still the same problem. I have it on a win7 and win10 computer.
Tried also 6.4. Same problem
Have also put SMB on 2.1, instead of 3.0
Connecting by cloud, no problem
Connecting via Raidar - explorer, no error
Jun 24, 2016Guru - Experienced User
Raidar's browse function just opens up explorer with \\nasipaddress
If you enter \\nasipaddress directly into file explorer's address bar you should see the same thing.
If you do, then perhaps your problem is related to windows credentials. Try deleting all credentials using the nasname, and re-entering one with the credentials you want to use.
- norrispackardJun 26, 2016Tutor
Hi all,
i have the same issue.
i believe the issue come from the OS used:
Windows 10 - cannot see on SMB normally, i see the server in the net but when click give 80070035 error, then open readyclud app and through it by clicking on the folder i access on it and in the net appear the ip address of the server ( try to type the ip by smb but not found before open the readycloud app)
anyway i can acess only on the folder of my remote account, no admin. to see all i must to use the admin page.
ubuntu 16.04 open the net and found only SMB server, acess using admin credential but i can see only the folder aloowed by remote account - no home folders also the remote account folder.
Android usinf FX Explorer - i can see all!!, home folder also.
Hope to be useful.
- MikeFHJun 26, 2016Aspirant
Look like a common isssue, not great!
Is this the same issue you all have ? - https://community.netgear.com/t5/Using-your-ReadyNAS/cannot-enable-any-readynas-services-in-netgear-readynas/m-p/1105663#U1105663
Any idea how to fix it?
Thanks
Mike
- Allard72Jun 30, 2016Aspirant
That is a different Issue.
I installed Windows 7 on an other computer and it works fine
Seems to be a Windows 10 - Upgrade 6.5 problem.
Also installed new certificate and credential changed. Nothing works..
Can not reach the NAS-Files by using Raidar..... Installation screen using NASIP is no problem.
Ping is also ok
Set also SMB in Regedit open for guests
any new ideas??.
