jkphoto's avatar
jkphoto
104 stuck on boot after firmware upgrade
I have just run the firmware update to 6.1.9 on my less than a year old Readynas 104. Everything was going as usual until the reboot phase of the update. Now the unit is stuck in booting. The display shows the message: Restarting Now. See you soon.
To make sure that it wasn't just taking an abnormally long time to boot I let it go overnight, however this morning it is still at the same point. The unit will not power down via the power button on the front and I am hesitant to unplug the power.
Can anyone help to get me back up to running?
  • Unplugged, waited 30 sec., plugged in and restarted.
    All seems to be back to normal.
  • Must be a common issue. Just updated my 104 with the same result...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Most of the time when updates are done it doesn't hang on booting, but in some cases it does. At least there is a quick solution if it does happen.
  • Have just had the same experience updating (via online interface) from 6.1.9 to 6.2.2, although the front LCD panel displays:
    "Booting...
    Updating FW"
    Blue power light flashing (does not respond to long press).
    Been going for 50min so far, will give it 2hrs then pull the cord and hold my breath...
  • I have the same issue - unplugged it but it did not come back up.
    Tried to reload OS from boot menu, but still failed.
    What next?
    mdgm-ntgr
    What do you see on the LCD when you try to boot it?
  • My LCD looks like it goes through the correct boot process:
    "Booting ....."
    At some later stage it then freezes and with a "Retrying Startup" message. There is likely to be other messages in between, but I haven't sit there and watched for them.
    When it hangs at the retrying startup message, the hard disk(s) sit there with a lot of activity happening
    Let me know if you need more info and I'll watch the complete boot process.
    Thanks
    Nick
  • Any solution to this yet? I got a new NAS, configured everything yesterday, powered on and and it got stuck on "Booting ......." for hours.
  • StephenB's avatar
    Contact support (support.netgear.com). If you purchased new, you are entitled to 90 days phone support.
ProSupport for Business
