netracer
Sep 17, 2012Apprentice
10Gb NIC Teaming with pair of Nexus switches
Looking if anyone has experience with connection a ReadyNAS 4200 with 10Gb ports in teaming mode, which teaming mode should be used when connecting to a pair of Cisco 5548 10gb switches running VPC? ...
OOM-9
Sep 17, 2012NETGEAR Expert
I have not seen tests with Nexus switch on the Cisco switch specifically. The speeds should be closer to the 10Gbps than the 88Mbps you are saying in the post.
Have you tried the 4200 with a single 10GE interface to see if you were able to get any faster speeds? (hopefully ruling out the LACP)
